So I have been working on my camera settings and I noticed under the network config that BI sees my 5442 as a Generic/ONVIF and the model option it choose was the RTSP H.264/h.265/MJPG/MPEG4. This is the window you open under the BI "Camera Settings>Video Tab>Config Button"
So now I assume under the video section of this window I need to build my Main stream and sub stream and the desired params I want? or are those built and populated based on the various settings I tweak in the 5442 Camera GUI?
The reason I ask is I have been working on my BI alerts and Camera motion sensor triggers and alerts. Based on my reading I should set up the Camera GUI settings first and not set any of the zones in BI correct?
But do I got lost on do I check "motion sensor" in the "trigger" tab and leave "motion zones" unchecked in the "alerts" tab as long as I have "Extern" and "ONVIF" checked? And I do the same under "email alert" properties under "actions"? Right now I don't use the phone apps for BI alerts, I just do email alerts. Instead of the phone app I thinking about going the VPN route.
I am wondering if the params not being right might be why my BI camera view is not updating the ROI I set at the camera in BI live view. BI seems stuck on the one I set messing around within it.
One more question I using h.265 with VBR for bit rate type, should I get overly hung up on the max bit rate? I currently set it to 4096, but as I understand it the VBR will vary but not go over the max of 4096 correct? I have yet to see what the point of i frame, is it that suttle that it is hard to see a difference in changing this?
