BI veteran needs pro help
bracurrie
Jun 11, 2014
3
I just don't have the time to devote to the hardware side of my BI setup. I am in Nashville, TN and have thus far struck out finding installers for cams. Everybody wants to quote and install a proprietary system of which I have had several and all have been terrible. I tell them I am ok with the software and configuration of BI but they all run away.
Leads or suggestions wanted.
Thanks Ahead
Brad
Hmm. If you can hire someone just to run network cables for you and crimp the ends, then it is pretty quick and easy to mount and aim cameras yourself.
Thanks Fenderman. I have found several of them but so far when I mention video cameras they shy away.
Thanks bp I will try that approach if I have to, but mounting the cameras is part of the problem for me with time as I do not have good ladders, drills and experience.
you dont want to mount the cameras high...you should not need a ladder for your install..
