I would guess you need to ENABLE Direct to Disc for each camera.
Something is very wrong with your set up because even without hardwood coding you would be nowhere near 100.Yes I have done that for each camera but there seems to be a separate option for hardware accelerated decode.
You can change the setting on the drop down in your screenshot to "No" for your wyze cams.
It seems once I started to change all cams to direct to disk, the cpu usage dropped drastically. Down to 25% now
You can reduce it into the single digits if you
Use the sub stream function see wiki
When you open the window to full screen it will show The main streamYes I added substream to some of them since the others I need to be able to see higher quality during live viewing. Thanks!
