C chuck n3wb Oct 15, 2014 18 1 Feb 16, 2015 #1 Am I missing something, or should I be able to clear the list of connections (minus any active connections) by hitting the Clear button at the bottom of the screen? Yes this is my only complaint running 13 cams for about 9 months on BI Software
fenderman Staff member Mar 9, 2014 36,891 21,417 Feb 16, 2015 #2 Yes you should be able to...what connection is showing?
C chuck n3wb Oct 15, 2014 18 1 Feb 16, 2015 #3 My past connections from various machines on the lan, my connections from remote locations, and unknown attempted connections. On the messages tab, that Clear button works, the cameras tab, the Rest Button works. Last edited by a moderator: Feb 16, 2015
fenderman Staff member Mar 9, 2014 36,891 21,417 Feb 16, 2015 #4 That is strange..if its not causing any problems i would just leave it alone.
