Is there any way for BI to signal that it has restarted? Specifically I'm looking for a way using HTTP got my BI to notify my Vera that it has restarted, for example after it has updated the version.
do not use auto update. You are simply asking for problems...Is there any way for BI to signal that it has restarted? Specifically I'm looking for a way using HTTP got my BI to notify my Vera that it has restarted, for example after it has updated the version.
I dont know of a way to do this...maybe im missing something but why would it matter to vera if the pc was restarted?I'm not using auto-update but I would like some way for BI to tell Vera if I manually update, restart the PC, etc. Vera manages BI in conjunction with the DSC alarm system settings to set the BI mode/profile depending on the alarm state so I like to keep Vera updated on changes.
I think you could use Blue Iris Tools, which has a built in watchdog interface which can launch a URL command if it detects BlueIris service down or restarted.
In my testing blue iris stays at the last profile setting even after a reboot.As an example, Vera sets the profile in BI according to whether the alarm is set Away Day/Night or Home Day/Night. If the PC restarts for some reason BI does not appear to return to the last Profile setting. If Vera could know the PC had restarted it could reset the BI mode to match the current expected mode for the current alarm settings.
