BI sending 100s of "Get Parameters" to Hikvision cam, is this normal? Sometimes it sends 4-5 within 1 second.
I was randomly checking the log of my Hik DS-2CD2442FWD-IW, and within minutes of a reboot (of cam) I saw 60-100 pings from my BI machine for what the Hik labels "Get Parameters".
The Hik is using IVS both intrusion and line crossing, no motion detection in BI.
So again, is this a normal amount of polling from BI, and does BI do this on all my cams? (only have an SD card in the Hik to record a log, so I can't check all my other cams)
