Now a few updates ago, my security system with BI was always around 55% to 65%, even during alert recording.
Recently it says it is running a quad core 4.6Mhz CPU on BI at 100% which is wrong according to Windows 10 task manager CPU logging. My task manager shows about 60-70% CPU usage of the BI program.
Does anyone know about this problem and if it is fixable. There should be no reason at all this BI program has to use 100% CPU continuously while sitting watching 6 cam channels at 20fps with direct to disk and no alerts. Just keeps climbing after each update it seems. I would like to see these %'s of CPU usage match each other like they should be.
There are no background programs running except for defender and the system is dedicated, so why does BI suck resources so much. Is there a workaround to sync up this CPU usage between BI and the Windows task manager or lower CPU usage to where it was working at on my system a few updates ago.
I keep dropping startup programs down where the system is almost 80-90% in idle process. Turn on BI and it sits using 95% to 100% using 1.15G Ram. Friggin irritating that it can not read CPU correctly. Why use it if it does not see the usage correctly.
