Hi all-
I switched my wifi to google nest Wifi which moved everything to another subnet. I reconfigured all cameras for the new subnet and
put the BI server on this same subnet. All cameras show up in BI fine. I also use Actiontiles. Came to notice if I do a telnet to my
server ip and port 81 I don’t get a connection. If I go to the command prompt and type in netstat -ano I see no port 81. Port 81 is the
configured port in BI. Even used Advanced Port Scanner on that machine and did not see port 81.
what logs can I check, or what can I check to nail this down? Actiontiles uses the ip and port in the url and I assume Actiontiles doesn’t
show the cameras bc port 81 is not responding. Ideas?
..ar
..ar
