Bi mobile suddenly showing dropped cams
Feb 4, 2020
7,796
12,554
Minnesota USA
Yet they all show up as remote cams on my Amcrust NVR
Reactions: djernie
What the what? The green stripe of death?
Check the BI logs to see what it says. Not sure that's what it is but BI drops cams much easier than some other VMS/viewers. And it takes a little while to recover when it does so you'll see it more. When it happens, check the time stamp in the Amcrest/on camera and see if it's actually moving or stalled. e.g., Some crappy Wyze cams I have can stall out for 5 or 10 seconds and their app looks like everything is fine unless you look close to see that the time's not moving. Never drops them, just shows a static image. BI balks immediately and drops them and throws up the problem screen until some time passes after it recovers.
A restart of each individual cam from the console straightened it out.
Seems Macrium Reflect was hogging the free space on the Seagate 8TB until the drive was 99% full. Screwing with the overhead BI needed to write and read. I had not restricted the backup disc image folder to a size equaling or exceeding the Blue Iris " new" folder size of 4TB.
Then I deleted about 10 Windows .ISO's from XP, 7 Vista, 8. which increased free space from 28GB to 64GB.
Then for good measure I moved ahead about 11 months in versions of BI...
Now I'm cloning the Seagate 8TB to a new WD82PURZ.
Transferring 8TB on a 99% full drive....o_O She's at 4% after about 30 min.
The WD82PURZ really got rid of system lag VS the Seagate drive. That and freeing up disk space to cure the 99% full error.
