C cmccarter Young grasshopper Jan 9, 2016 32 0 Mar 15, 2016 #1 Just installed the android version of BI for my phone, seems to work great, but how do i keep the hidden cameras from showing? They are clones that i use for triggers
H hltljohn Getting the hang of it Oct 29, 2015 90 42 Mar 15, 2016 #2 Blue Iris Options, Users, Edit Users, "Limit to camera groups", then select the groups that you wish that user to see when they login.
fenderman Staff member Mar 9, 2014 36,891 21,409 Mar 15, 2016 #3 hltljohn said: Blue Iris Options, Users, Edit Users, "Limit to camera groups", then select the groups that you wish that user to see when they login. Click to expand... This will prevent push Alerts from coming through to the user... I believe there was mention of an upcoming update that should allow this...
C cmccarter Young grasshopper Jan 9, 2016 32 0 Mar 15, 2016 #4 Really want the best of both worlds. View only the live cameras but still receive alerts from the clones. Will try groups and see how that works.
R ruppmeister Getting the hang of it Apr 15, 2015 668 98 Mar 15, 2016 #5 Not sure about the Android app, but iPhone has the option to display hidden cams or not via BI app Options > Hide Cameras > Yes/No. If it isn't in the Android version I would be willing to be that it will be at some point to match what is available on iPhone.
fenderman Staff member Mar 9, 2014 36,891 21,409 Mar 15, 2016 #6 ruppmeister said: Not sure about the Android app, but iPhone has the option to display hidden cams or not via BI app Options > Hide Cameras > Yes/No. If it isn't in the Android version I would be willing to be that it will be at some point to match what is available on iPhone. Click to expand... Yes, there is a thread or release note which mentions its coming to andriod..
