BI Macros Question
eyeball
Getting comfortable
Jun 30, 2014
245
569
Hey Folks -
In customizing emails sent in alert conditions I noted the following:
In the email Subject, &TYPE is the alert type &CAM is the short camera name. These appear to only work in the Subject and not the body of the email.
In the body of the email, %s is the long camera name. I found other macros (or substitution variables, or whatever you refer to these as) in the time formatting documentation, such that I can format the email this way:
Date: <b>%A, %#d %B %Y</b><br>
Time: <b>%#I:%M:%S %p</b> <br>
FPS: <b>%f</b> <br><br>
ALERT: <b>Motion detected on %s</b> <br>
Does anyone know of a complete list of "%" and "&" macros that are supplied and interpreted at usage time by Blue Iris?
Thanks!
Here's a list date and time formatting codes from the BI Help file.
%a Abbreviated weekday name
%A
Full weekday name
%b
Abbreviated month name
%B
Full month name
%c
Date and time representation appropriate for locale
%d
Day of month as decimal number (01 – 31)
%f
Frames/second (FPS) for camera
%H
Hour in 24-hour format (00 – 23)
%I
Hour in 12-hour format (01 – 12)
%j
Day of year as decimal number (001 – 366)
%k
Kilobytes/second (kB/s) for camera
%m
Month as decimal number (01 – 12)
%M
Minute as decimal number (00 – 59)
%p
Current locale's A.M./P.M. indicator for 12-hour clock
%S
Second as decimal number (00 – 59)
%U
Week of year as decimal number, with Sunday as first day of week (00 – 53)
%w
Weekday as decimal number (0 – 6; Sunday is 0)
%W
Week of year as decimal number, with Monday as first day of week (00 – 53)
%x
Date representation for current locale
%X
Time representation for current locale
%y
Year without century, as decimal number (00 – 99)
%Y
Year with century, as decimal number
%z, %Z
Time-zone name or abbreviation; no characters if time zone is unknown
Percent sign
You may place a # character immediately following the % to eliminate leading zeros in many of the formatting codes. For example, %#H will show 9 at 9am instead of 09.
Time Zone Correction
For time zone correction in a text object overlay, add the special sequence {+n} to the beginning of the string, where n is a number 1-23, and the sign is either + or -. For example, a text overlay of {+3}%c will display the time 3 hours ahead of local time.
Reactions: Caspy
Hey thanks for the response Mike - I found those in the doc before I posted and have made use of them, but I was wondering if there are <i>others</i> that are available (for example "%s" is not documented in that list, but it provides the long camera name).
Got ya, hopefully someone else will post them if they know them :)
Id love to see some added, like Lat and Long info.
also i think the "%m kB/s" is broken... its steady at 11...
anyone have a clue why it does that?
attachment.php
Disreguard. I was using the wrong switch.. it should be %k. fixed it. My bad.
Is it possible to get Core Temp (an app that captures CPU temp) in a macro?
