Hey guys...saw a number of helpful posts here so as a user brand new to BI I figured I'd post about a single issues I'm having that I really hope I can get figured out. Seriously hoping someone here as some wonderful thoughts
So I recently purchased and installed Blue Iris on a Windows machine of mine, and successfully added a couple basic Android phones running "IP Webcam Pro" (IP Webcam Pro - Android Apps on Google Play). Yes, I am completely aware it's nothing fancy, but it works for the minimal needs I have...someday I hope to expand it, but it's more of a "want" than a "need" at the moment
For now the setup I've got works as a proof-of-concept which is all I need right now
The issue came however when I went to start using the mobile app - I could successfully view both of my cameras, and I could successfully hear audio FROM the camera TO my phone, but I could NOT get audio from MY phone to broadcast back through the camera. So audio only works one way.
I would even question if my super simple (and cheap) setup even had such an ability, but I know it does as Tiny Cam (also on the play store - tinyCam Monitor PRO - Android Apps on Google Play) has this ability and audio both ways works FLAWLESSLY. As such, I'm pretty certain this is an issue somewhere on the BI side of things, so please let me what you guys would suggest as my next steps of troubleshooting or if anyone has encountered any similar issues. I really, really want this ability to work (without being forced to use 2 apps). Thank you!
