BI install insructions
dryfly
May 25, 2015
260
46
I recently ran across a post which showed detailed instructions for a Blue Iris install and setup, i.e. step by step. I can't remember if it was on this forum or another. Unless I'm just dreaming this I'd appreciate if anyone could direct me to this post.
Thanks in advance
Thanks in advance
The installation is self explanatory...once installed the help file has a getting started section with detailed instructions...
In the record tab of each camera under file format, be sure to select direct to disc..also use the blue iris dvr (bvr) container.
Yes I know about the help files but wanted to look at the software setup before an install. What I think I saw would be very helpful for the first time user.
