Anyone come across this series of errors before during an update? I also can't kill the BI process (Win7 x64) machine. Done a fresh install but still recurring and need to reboot each time which is not ideal.
Download the update from the website. Shutdown BI and apply the update. I have never had an instance where task manager cannot kill BI.Hi, just chiming in with a similar problem. When I do the update through BI I get the same first error message you show with "BlueIris.exe failed(32)-make sure not in use". I also can not shut down BI through task manager. I do not get the other error messages though, the update will hang so I cancel and try again and eventually it goes through and BI is fine EXCEPT for another problem, when I then try to use the iPhone app the port I use for forwarding does not work anymore so the app does not work and I must go in to my router and change the port for forwarding then change it in the iPhone app to match it to get the app to work. I am sure our problems are related and what I see is that you and I have 64 bit but the problem is loading and failing 32 bit? Any help out there?
Thanks, Adam
that is impossibleFYI Fenderman the ip address has not changed, only the port number for port forwarding becomes no good so I have to assign another port number for forwarding but just that. Thanks, Adam
