N Norgreen n3wb Sep 3, 2016 16 0 May 22, 2018 #1 Hi I have BI with Hikvision cameras and keep getting mobile notifications for when the sunlight changes due to clouds. Would I be looking in the Hikvision WDR or is there an optimal BI setting. Thanks
A anijet Pulling my weight Mar 10, 2014 363 189 CA May 22, 2018 #2 I've eliminated "most" shadow false triggers by using multiple zones and zone crossing. Object travels setting helps some also. Reactions: aristobrat
N Norgreen n3wb Sep 3, 2016 16 0 May 22, 2018 #3 anijet said: I've eliminated "most" shadow false triggers by using multiple zones and zone crossing. Object travels setting helps some also. Click to expand... Any chance you could elaborate on this please.
bp2008 Staff member IPCT+ Member Mar 10, 2014 12,886 14,482 USA May 22, 2018 #4 Those are options for Blue Iris's motion detection and I believe they are discussed in Blue Iris's help file.
A aristobrat IPCT Contributor Dec 5, 2016 2,979 3,179 May 22, 2018 #5 Look at this suggestion: #49 And watch video #8 (Triggers: Object Detection) on this page: Blue Iris Video Tutorials
