Seems more likely to happen if I'm viewing remotely from UI3 using either Chrome or Edge. These are the two errors with the 2nd being the most common. This has been happening for quite a few versions now and I guess I keep hoping it will be addressed with each update that comes along. Any ideas on where to go deeper in troubleshooting? Hardware is a Ryzen5 3600, 32GB of RAM and with a GT1030 in the machine I handle of the camera processing via the CUDA cores. CPU in the machine usually runs at about 25-30%, nVidia card at 35% consistently and the card is plenty cool. the BI process levels off and usually stays comfortably at 7-8GB of RAM consumed so I'm not thinking this is resource-related.
Faulting application name: BlueIris.exe, version: 5.6.0.6, time stamp: 0x6304f083
Faulting module name: ucrtbase.dll, version: 10.0.22000.1, time stamp: 0x00e78ce9
Exception code: 0xc0000409
Fault offset: 0x000000000007dd7e
Faulting process id: 0x1a60
Faulting application start time: 0x01d8ba3d49df6da0
Faulting application path: C:\Program Files\Blue Iris 5\BlueIris.exe
Faulting module path: C:\WINDOWS\System32\ucrtbase.dll
Report Id: c0e1abd1-4e87-4d20-8911-7a94d6b8c7b8
Faulting package full name:
Faulting package-relative application ID:
Faulting module name: ntdll.dll, version: 10.0.22000.832, time stamp: 0x3907dfbc
Exception code: 0xc0000374
Fault offset: 0x000000000010c9a9
Faulting process id: 0x1298
Faulting application start time: 0x01d8b9973d6af34f
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: af8c5d40-e40f-45c6-9802-e6b191edc875
