- Aug 31, 2016
- 32
- 7
First post and first camera ever, fresh BI install. Have read for many hours and searched for this problem, but cannot find a solution to what has to be a silly easy problem! I am fairly network literate, but not much more than that.
I have a brand new Hikvision DS-2CD2342 camera on my network (powered by a poe switch.) I can access the camera via web admin, and everything is pretty much default; I only changed the IP and camera name, etc. It is set to Server port 8000 and http port 80. Using Firefox, I can see a live picture from the camera from this url http://192.168.1.100/doc/page/preview.asp
I installed Blue Iris, added the correct camera type, and in the server address on the add camera/video setup page, I used 192.168.1.100:8000 in the address bar, but BI can not find the camera. If I try to let BI find/detect the camera it cannot find it either. Also , if I remove the :8000 from the address bar it cant find it.
Note: there is no field on the BI video setup tab to add Server Port (8000), which is why I add it to the url string. I have seen other screen shots of BI on this video setup tab where a separate field was presented to add server port, presumably leaving the address bar to just the ip (w/o port) Mine doesn't have this.
Note: I can ping the camera using its ip, but not if I add :80 or :8080 to the ip address.
Support data:
Blue Iris Version: Release 4.4.3.3 x64
OS: Windows 7 Professional
Would love some help for anyone willing to help. I have included a few screenshots for reference.
Support data:
