Hi all,
I have Blue Iris running behind Nginx in a private LAN.
Here is my current Nginx configuration (Ubuntu 24.04 lts):
Version 6.0.3.8 – works fine through the proxy
Version 6.0.4.4 – returns 502 Bad Gateway with the same setup
A logged-in user sees endless errors in UI3:
Other:
Additional details:
BI is on a Windows 11 machine at 10.77.50.10
Nginx is on a Ubuntu server at 10.77.50.25
Windows Firewall has an allow rule for blueiris.exe on port 81
The network uses a load balancer with multiple WAN IPs, which periodically change
Has anyone experienced similar issues with BI behind a reverse proxy, especially in a setup with changing external IPs?
Is there a known workaround or setting to fix this intermittent 502?
Thanks in advance!
P.S.
I wasted a lot of time, rolled back from the latest version to 6.0.2.10 and everything worked perfectly.
NGINX:
server {
listen 80;
server_name example.com;
return 301 https://$host$request_uri;
server {
listen 443 ssl http2;
ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem;
location / {
proxy_pass http://10.77.50.10:81;
Other:
Additional details:
Thanks in advance!
P.S.
