- Jul 13, 2016
- 29
- 0
So... I was developing a "camera viewer" to display a bunch of camera feeds (sub streams) on an office TV... but that became an issue with the DLL i found (has a memory leak).
Anyways, I thought after spending about 5 hours coding, and researching... that for $60 I could have just bought BI, and had a full feature viewer
Now, I have all the cameras set up on sub feeds, they are at 704x480 @ 1Mbps @ 6fps (I don't need much), and an i3-2100 is running at like 35% (50 cameras, no recording).
I want to have it display a bunch of the cameras, in a configuration like (but bigger):
XXXX XX
XXXX XX
XX
XX XX XX
where the big XXXX block cycles through the other cameras... Is that possible? Also, would like to highlight the motion in a thicker border as well if I can.
Is/are there better ways to achieve this? Am I asking too much? It does work great as it is right now, just looking for more tweaks
Thanks in advance!
XXXX XX
XXXX XX
XX
XX XX XX
Thanks in advance!
