D Dorsey Pender Getting the hang of it Sep 7, 2019 215 30 San Francisco Oct 28, 2021 #1 Has anyone tried to run Blue Iris as a virtual machine on Synology?
S Scale Getting the hang of it Apr 14, 2020 150 17 . Nov 11, 2021 #2 Have you tested BI with VM on Synology?
D Dorsey Pender Getting the hang of it Sep 7, 2019 215 30 San Francisco Nov 23, 2021 #3 Synology VM test performance is poor after testing just running Windows 10
DG99 Getting the hang of it May 1, 2019 69 60 Minnesota Nov 23, 2021 #4 The CPU is Intel Celeron J4025 2GB memory, running synology + windows on 2 Gb ram. You would need the big Synology for an VM.
D Dorsey Pender Getting the hang of it Sep 7, 2019 215 30 San Francisco Nov 23, 2021 #5 I upgraded the memory so I could run Windows 10 for DR.
Mark_M Known around here Jul 2, 2019 1,258 1,715 Land down down under Nov 28, 2021 #6 If you are at the point of running Blue Iris on a Synology NAS, I would question why you don't just purchase the Synology NVR solution. and if you are willing to buy a Synology NVR... then instead buy another PC to run Blue Iris. Reactions: kklee and sebastiantombs
