Hi Team. Recently, Hughesnet started providing Public static IP addresses, if you have a biz acct and pay for it. I got this acct specifically to use with BI for remote viewing. Unfortunately, BI does not seem to work consistently with my system and I am not sure why, although I have a suspicion.
When using the Remote Configuration Wizard, one of the last steps is for the software to confirm the Public IP address that is entered in the very beginning of the configuration process. I noticed that BI would sometimes confirm the correct address I entered, and sometimes a very different address entered (which failed verification). I spoke to Hughesnet about it, and they said both were Hughesnet Public IP addresses, but they did not know how BI was finding the "other" IP address and not my static IP address.
Is there some kind of bug in the BI software that can cause the address verification to be wrong? I need to know because I am remote much of the time and need to check on this site.
Note that I have actually had the system working on and off for a short periods of time where I can see my cameras remotely, but then it stops. The Public Address for this server is pingable as well, but the error that comes back is:
Unable to Connect. Please try again.
Reason: Unable to reach server.
Any ideas as to what might be going on and how to fix this connection issue other than getting rid of Hughesnet, which unfortunately, is not an option?
