In the ONVIF events dialog, the 'Memo/label' field is alternative text for the usually lengthy string in the 'Contains' field.
Thanks for the Help PDF excerpt. I tried to search for it, but not hard enough apparently!This is part of the ONVIF Events Help describing the Memo field
Memo/label (optional) this will added to the alert memo in the database, and may
then be used as a “required AI object” for alert actions. If left blank, a
combination of the contains and attribute fields for the event are used as
the alert memo.
I did exactly that. Within the ONVIF Events dialog (see above image), I changed the memo field from {EVENT} to TripWire. In the On Alert dialog, I added TripWire to the Required AI objects field.
When a TripWire event is triggered the BI log shows:
0 11/11/2023 12:43:00.452 PM Driveway ONVIF Event: TripWire
3 11/11/2023 12:43:00.463 PM Driveway ONVIF (TripWire)
I get recorded clip that is labelled ONVIF TripWire. But the OnAlert does not fire. No idea why not
Suggest sending an email to Ken.
