BI 6.0.3.2 is agressively auto-banning my home assistant server
brianod
Jan 29, 2024
1
USA
After installing 6.0.3.2, it will ban my home assistant server. In the Limit Access by IP Address field in the Web Server tab, it will put -[ffff:192.168.5.15] which is my home assistant server IP.
I removed the entry. I turned off Auto ban. Restarted the service. The ban entry continues to come back no matter what I select.
It could be either the HACS Home Assistant integration, or I am using uptime Kuma to monitor http://<ip>/ui3.htm. However once I disable both those agents, the ban will still continue to come back. even when they are off, so there's no easy way I can tell to see if its one service over the other. Probably safe to assume its the HACS integration as I think uptime kuma is only doing a curl.
I also removed all of the new "Ban User Agents" entries. Still same problem.
Rolling back to 6.0.2.10 is the only thing that fixes this.
Please advise.
Please advise.
@brianod did you manage to get your issue resolved? I'm convinced there is some sort of bug with the banning mechanism.
