There is none...any camera can be made wireless with a wifi bridge....stay away from any wifi...'Best' is obviously subjective here but i was looking to get a Turret camera with IR and I like the HIKVison ones but they dont do a wireless variant.
Can i ask for views on which ones you would recommend and why?
sure...
Facial recognition meaning it recognises people and identifies them or its just good enough to make faces out well? Its the latter.
rear of the house is pitch black with no lighting other than some LED floodlight with low lumens which is only on back door. So would want something to pick up those who are lurking outside the field of the PIR of the floodlight - maybe 20 foot out -
Front has street lights shining on drive so using IR wont add much there but the lighting is not great so something to work well in low light non-IR would be good... max distance maybe 15 foot ...
outdoors
want it to have smart events - dont need 24x7 recording just event handling..
That help?
sadly no - these will be wall mounted with no cover above them ....
Get ready to hate on me...
Now that you mentioned it I don't see any ip67 or ip68 rating for the first camera here
I would make sure before u buy
Hikvision Full HD 1080P 2MP wireless wifi IP PTZ Network Camera DS 2DC2204IW DE3/W with audio&alarm interface wi if camara poe-in Surveillance Cameras from Security & Protection on Aliexpress.com | Alibaba Group
your really limiting what you can do with that $200 per cam then; because of the problems w/WiFi and Security none of the serious manufacturers give it much attention.. they might put it in a few consumer grade devices or you can really overpay for some cheap junk that wont perform anywhere near as well as you'd of got out a wired connection..
Ive yet to see an outdoor rated, consumer wifi camera that was not overpriced junk in comparison to what you can get from commercial video surveillance equipment.
Even with just a couple of WebCams on Steroids you'll be better off with wired PoE, all metal cameras that will last for years w/out hassle.
Says outdoor wifi 200m WTF that means
