- Dec 21, 2017
- 1,288
- 1,201
Hi folks,
I moved all my cameras over from a Hikvision NVR to Blue Iris this weekend. Everything is working fine except one camera's stream isn't detected. I get a No Signal 404 stream not found. IT worked fine on the NVR.
Yes, this one cam is a cheapie... the only "non Hik or Dahua" on my system, so I'm expecting answers like "solution: toss the camera and buy a Dahua" (
) but the camera was doing fine for its application before and I'd like to troubleshoot whatever the problem is.
I've got the IP address fine and I can log into the camera no problem; stream looks good when I hit the address from a browser. I've set the cam to use a couple different frame rates, CBR and VBR, etc..
Any ideas?
Inspecting it gives:
Set up as:
I've added it as a "Jennov" or as a "Generic" and both give the same result.
Thoughts on next steps?
Any ideas?
Set up as:
