Best way to purge All Clips?
105437
BIT Beta Team
Jun 8, 2015
2,196
1,085
I had a couple of cameras go crazy with new settings and I'd like to know the best way to just purge all the clips from those two cameras. Any tips? Thanks!
Stop BI service.
Go to video folder and delete the video from those cameras.
Restart BI and select repair/regen DB
Reactions: 105437
There is no benefit to doing this. Just let BI overwrite with new video naturally. You can also simply just select all the clips within blue iris and delete. In the clip viewer click on selected camera only then hit control+a and they will all be highlighted. Then delete.
Reactions: 105437
Thanks for the replies. @fenderman I'm trying your method of selecting all and then selecting "Delete -> Destroy" since I don't need them at all. Appreciate it!
