Best solution to turn Wi-Fi camera into public IP camera
dude1
Dec 2, 2018
7
2
New York
I have a Keriu GQC09HE.
I connect it via Wi-Fi and can see the image in the Care Home app on Android.
I also have the IP address of the camera on my network (http://192.168.178.1 or http://192.168.178.1:80).
I searched for solutions to stream the signal online, so that I can watch it on my computer for example, but I find all solutions incredibly complicated.
Any recommendation for a simple solution to access the image from anywhere, preferably to make it public with just a URL?
Thanks
Thanks
Youtube is definitely the solution I found the best and that's why I looked for the IP address of the camera on my network.
The problem is that Youtube only seems to let me select the webcam of my laptop, I can't find any way to stream that wi-fi camera.
Any hint?
Thanks
Thanks
Any hint?
Thanks
Did you scan a QR code when you installed it?
Maybe it's P2P, and the IP address isn't visible.
I didn't scan a QR code, but I went through the wifi setup through the app on my phone.
Worst case scenario, I'll go through this procedure which seems to be what I'm looking for.
I just hoped there was a simpler way.
