Hi guys .
My setup :
16 1080P camera no POE mixed brand.
Actually I am recording on a dedicated laptop that has 2 purpouse
- Run DDNS software (DUC NOIP service)
- FTP server for ipcam
The problem is that only some cams can write video to FTP following a motion alarm others can write only shitty JPEG.
I don't care about cloud service , all the camera is seen remotely by port forwarding setup and tinycam software on android phones
So I am thinking to record all the stream 24/24.
Can you suggest me the best solution? NAS? NVR?
Something like this could work?
http://goo.gl/0j1un2 paired with 2tb purple WD hard disk?
Should I still use laptop for DUC noip serivce ( or better shift it to a raspberry?)
thx for your help.
Andrea
My setup :
thx for your help.
Andrea
