Best Day/Night Outdoor PTZ IP Cam Value
eyeball
Getting comfortable
Jun 30, 2014
232
540
Hi folks - looking for recommendations on the best value on a general use PTZ IP camera ... In an entry class price range. No particular spec requirements, just best quality for least price.
Thanks!
Honestly there is nothing of any quality in that price range. You can take a risk with some no-name aliexpress cams but in my opinion its not worth it.
Probably the Dahua SD59212S-HN.....wrightwood has it for 609, aliexpress for a bit less 531....
Thanks @fenderman ... Btw I have a 76 strat I bought new back in the day amongst the gibsons in my stable - still a very sweet player all these years later!
x2, Great Residential PTZ that will give you a very long service life.. Its very well engineered and IMHO its everything a good PTZ should be.
You could try to save a hundred or two with some really cheap cameras but I doubt you'll be thrilled with the results and the longevity of cheap moving parts.
Would you need IR's or is there some sort of lighting around the area you want to view?
Night + Outdoor + PTZ; I have to assume he needs IR; especially for residential as most people dont live in a well illuminated parking lot and only have a few select places lit well enough to see anything at night without IR.
I have one left in my stock if your interested and I will beat any price you find online.
do it; you'll own a camera thats better than what'd $1200 would have got you just a few years ago.. the HD (2MP+) sensors are cheap, great performing and plentiful now, its a good time to buy.
@vector18 - just thinking about it at this point; will check with you before I buy for sure - thanks much!!
Also the Dahua SD42212SN, 12X, 1080P vandal resistant PTZ dome, $459 on sale for Labor Day with free shipping at Wrightwood Surveillance. I think that would be your best buy out there. Has very good low light performance.
