Hi folks -
Moved into a new house, new opportunity to try out some new cameras. I also switched over to Synology as my NVR from Milestone and wanted to try out some of the new AI cam offerings and the integration. Purchased a IP8M-2696EW-AI to play around with and it integrated with Synology flawlessly. Very happy, and I can now alert on AI hits and/or motion detection, which is great for reducing false alarms.
However I know I'm going to be disappointed the minute I put it outside, at least compared to my really old 1.3MP IPC-HFW4100S's. I really like the AI aspect. What are some current, mature products with AI firmwares and good low-light (IR) performance + good illuminators? Seems companies have really dialed back the illuminators lately? Used to be common to have a full ring of them and now you seem lucky to get more than a half dozen, LEDs, if that?
No LPR for now, just general coverage of front/sides/rear of exterior. There is zero street illumination, we live in the country so starlight only. Most of the exterior lights have the ability to be automated but I don't yet have the motions. We typically don't keep them on as matter of practice.
Out front, one critical features I've found is the ability to 'mask' areas to be excluded from WDR or auto-exposure. We have white cars so the hoods/roofs tend to cause many cameras to underexpose/mis-shutter for areas of interest surrounding the vehicles. So this will be something I'll look for. I'd like to position one of the cameras between / above the garage doors, which captures all the way down the driveway as well.
Integration into Synology is important, but I can check their compatibility list, which I've found seems to offers less 'quirks' than straight up ONVIF.
Thanks in advance for your time.
