Belben 1583A CAT5e cable + TP-link TL-POE150s injector
wepee
Jul 16, 2016
263
60
Hi there,
I am just wondering if I have a Belben 1583A CAT5e cable:
https://catalog.belden.com/techdata/EN/1583A_techdata.pdf
(This is the only best full copper wire 24AWG available at my place)
and.............. I am going to use an injector:
TL-POE150S | PoE Injector | TP-Link
Will there be any significant signal attenuation, if the cable horizontal length
is 145 feet + vertical drop is 10 feet (total = 155 feet / approx 47 metres).
Will the signal strength is so degraded that once the POE camera is connected,
there is not enough power to turn it on?
Most appreciated if someone can give some advice with my question.
Thank you.
Regards,
Marcus
