- Mar 11, 2018
- 27
- 4
Hi,
This is my first go at networking and cameras, so please bear with me.
I was wondering if anyone put together a beginners step by step to starting a BI system. I ask because I have found that many professionals I work with have the aptitude to learn but are, like most technicians, hesitant to dive into fields they are unfamiliar with. Im a high pressure controls (15k psi) specialist, but know nothing of networking. Many of my coworkers have resigned themselves to off the shelf systems because of the learning curve. Id like to learn this and start converting them. I work offshore, so most of my coworkers have systems out of necessity.
I ask because I am starting my adventure into building a BI system. Lots to learn and the cliffnotes have been helpful.
Its embarrassing to really admit how little I know on a forum like this.
So as a starting point for myself; I am using a demo of BI on a Qosmio I7 3rd gen laptop, a 16 port POE BV switch, a 5231 starlight turret, and a 4231 starlight mini dome. Once I can get this system functional, I will purchase a dedicated desktop and start adding cameras to build a real system. It will be easy to justify costs as my abilities grow.
I got my cameras from Andy a day ago and was hoping I could just plug them into my BV switch and into my laptop, no such luck. Does the system need to go though a router or can it be a stand alone? Can my laptop's wifi serve as a internet connection for now? Where do I start with getting BI to search for the IP address of the cameras. I did see on another post that it was recommended to identify each camera individually.
As I stand now, my laptop is connected with cat 5 to the switch on port 18. The 5231 cam is on port 1.
Also do I need to use the little CD that came in the box for anything? I removed my DVD drive on my laptop and replaced it with a HDD. So if its required, I need to buy a usb DVD.
Thanks again for any help and tolerance. =)
Sky
Sky
