Hello!
I have been searching the site and read the cliff notes and just wanted to review what I was thinking to see if its accurate.
I'm looking to get 2 or 3 cameras. I have decided on the IPC-HDW5231R-ZE or the HDW2231R-ZS I was thinking use the 5231 by the door and by the garage door and use the 2231 more on the side of the house.
For the NVR I was thinking of the NVR4108-8P-4KS2. I believe this has POE and I would just need to buy a HD to put in it? I assume this would be enough to power the three cameras and be a good start.
Question is around accessing the video and setting triggers. Do most people use the SmartPSS software on a computer to monitor (of course if you have the nvr plugged into a TV or monitor you could do it this way too) The reason I ask is I would probably have the NVR upstairs in our bedroom hooked up to our TV but downstairs in the office I would want the ability to check the cameras. Can I also use the iphone app iDMSS lite to view the video and receive push notifications if it detected movement? Maybe another question if I set the cameras to record 24/7 can I get notifications if they detect movement or is that only if set them to record on movement?
I have a linksys router running tomato by toastman and I have read about locking things down and using VPN. I have no problem connecting to VPN to view the cameras but would I lose the notifications? Just curious how people check the cameras or get notified without going directly to the NVR and scouring tons of footage. Sorry for the long post but is just intimidating jumping in. A buddy told me to just get the Arlo Pro2 but I dont want to change batteries all the time.
Thanks for reading.
Thanks for reading.
