I only have 4 cameras. I need an inexpensive mini PC. I bought one of these and am running W11 fine. I can get an 4TB M2. Anyone using a Beelink?
I’m asking if anyone is using a Beelink?OK, there are a bunch of Beelink PC's, which one did you buy! Are you asking if it will run BI or just if anyone is using a Beelink Mini PC specifically or are you asking if anyone is using a Mini PC to run BI
stop buying this junk and buy a used desktop off ebay with a legal windows license.I’m asking if anyone is using a Beelink?
Thanks for the advice, I will keep it in mind.stop buying this junk and buy a used desktop off ebay with a legal windows license.
If you’re using a Beelink mini PC with Windows 11 and are adding a 4TB M.2 drive, you should be in good shape. Beelink PCs are known for their versatility and performance. Just ensure the mini PC supports the M.2 drive size and type you’re planning to use. I was in a bind with a challenging paper, so I used Do My Paper | Paper Writing Service | Write My Paper for Me The experience was outstanding. The writer provided a well-researched, well-organized paper that met all my requirements. The communication was smooth, and the paper was delivered ahead of schedule. The quality of work was exceptional, and I’m very pleased with the results. This service saved me a lot of stress, and I’ll definitely be using it again.
I have a Beelink that I use.... as a micro computer that runs a display in my kitchen that shows the status of my home automation system. It works great for that. I wouldn't try to run BI on it. How are you going to save the recordings?
I use a older computer (i7-8700) that I picked up off EBay for about $200 to run BI on.
I suppose it depends on your storage needs. My NUC is using a 2TB SATA SSD and 2TB M.2 NVMe in a ZFS mirror on Proxmox and then USB passthrough an external 12TB HDD to the Blue Iris VM. Video is migrated from the BI VM to the external HDD when the VM storage hits about 95%. In total, I get one month's worth of 24x7 video recordings. Those Beelinks appear to be great products though.
I realize there are solutions to add storage. However the main reason to get a NUC is if you need the small size IMHO. There is no other reason to deal with the negatives that come from such a small form factor unless you really need the small form factor. If you are going to add USB storage, why not simply use a slightly larger form factor that can support internal hard drives? Also, most SSDs and NVMes aren't designed for 24/7 recording (or you are going to pay an arm and a leg for a device that is rated for that constant use cycle), so that's not a great solution either.
What were your negative experiences with this type of setup that made you go a different route?
Hmmmm...nice user name.I have beelink and they are better than any used Windows 98 PC you can get off ebay. Also windows is the most unstable OS you could run and only used by betas. If you want to be a sigma giga chad, use linux.
I use Arch btw.
No one is telling you to buy a 20-year-old PC on eBay... Use your common sense... It is cheaper and safer to buy a used Dell or HP that is only two to three years old... It will be significantly more powerful and won't have Chinese firmware... You can enjoy the malware you paid for...I have beelink and they are better than any used Windows 98 PC you can get off ebay. Also windows is the most unstable OS you could run and only used by betas. If you want to be a sigma giga chad, use linux.
I use Arch btw.
Do you not really understand the difference between manufactured in China by an unknown China company that writes the bios firmware vs assembled in China? Iphone is also made in China but does not have the security issues of a China company shit phone.Dell and HP products are also manufactured in China...just saying.
Nothing is immune. But there are no checks and balances with china companies. There have been plenty of reports of beelinks arriving with malware on their systems with preloaded windows (google is your buddy). Much harder to detect it in the firmware.I do understand the difference, but Dell, HP, Apple, etc... are not immune from "tampering" during the manufacturing process. Plus, you cannot say 100% that Dell, HP and Apple do not sub-contract Chinese developers for some or all of their product's firmware. You also have no proof that Beelink firmware contains Chinese malware nor have there been any reports of this. You're giving too much credit to "U.S." companies that care nothing about you most of which are influenced/controlled by foreign interests.
