hopalong
I nuked the docker container as the LPR module was borked and re-installed 2.1.1 BETA. Working fine now with BI and AI Tool.
2.1.1 on unRaid Docker kept throwing me this error "ObjectDetectionNet.dll: Unable to get request from objectdetection_queue for ObjectDetectionNet". Rolling back to 2.0.8 for now
What does "nuked the docker container" mean? I uninstalled 2.0.8 before installing 2.1.1 thinking that'd be a clean install. Didn't work.
Thanks,
Mike
With version 2.1.1 none of the module are install during the install. They get installed once the service starts up. each module will take several minutes to install.Oh. I'm on Windows and not using Docker. I can install 2.1.1 and it seems to work for maybe one trigger and then the server stops on its own and has to be restarted. I don't think 2.1.1 is even installing properly. 2.0.8 installs for like 10 minutes and you can see a lot of modules installing in a command prompt. 2.1.1 finishes in like 60 seconds and you don't see any of that: like the install isn't going all the way through.
Mike
2.1.1 is giving me the same issues 2.1.0 was giving me. 2.0.8 is reinstalled.Interesting. I'm not seeing that behavior. When I start the service, it doesn't appear to install anything and I tried to verify that by looking in the log file.
I have the option to save a high res jpg turned ON in the "trigger" tab, which saves a jpg in the Alerts folder, because as far as I can tell that's the only way to get Pushover to function properly with BI. I did try to use the similar option to save a jpg from the "RECORD" tab instead, and save it to the "stored" folder, but I couldn't get Pushover to see those jpgs and alert properly (after changing the curl parameters to reflect the change in the alerts tab). Is there a problem saving the jpgs to "alerts"?You alert folder generally can be set very small 1gb or less because nothing is actually stored in that folder unless you store high res alert images - which are not needed unless you have a specific case use.
You dont need to save an alert image for pushover anymore. @jaydeel posted an update here. Send Pushover notifications with pictures and hyperlinksI have the option to save a high res jpg turned ON in the "trigger" tab, which saves a jpg in the Alerts folder, because as far as I can tell that's the only way to get Pushover to function properly with BI. I did try to use the similar option to save a jpg from the "RECORD" tab instead, and save it to the "stored" folder, but I couldn't get Pushover to see those jpgs and alert properly (after changing the curl parameters to reflect the change in the alerts tab). Is there a problem saving the jpgs to "alerts"?
That said, you can still use save high res alert - just keep the folder small 1gb or less. so it doesn't contain 200,000 files. The problem arises when the database has to deal with many hundreds of thousands of files.
&ALERT_PATH is still returning the temp file, like temp_{camname}.jpg,
15:33:18:Server: This is the latest version
15:34:23:Preparing to install module 'YOLOv5-3.1'
15:34:23:Downloading module 'YOLOv5-3.1'
15:34:23:Installing module 'YOLOv5-3.1'
15:34:23:YOLOv5-3.1: Installing CodeProject.AI Analysis Module
15:34:23:YOLOv5-3.1: ========================================================================
15:34:23:YOLOv5-3.1: CodeProject.AI Installer
15:34:23:YOLOv5-3.1: Checking GPU support
15:34:23:YOLOv5-3.1: CUDA Present...False
15:34:23:YOLOv5-3.1: Allowing GPU Support: Yes
15:34:23:YOLOv5-3.1: Allowing CUDA Support: No
15:34:23:YOLOv5-3.1: General CodeProject.AI setup
15:34:23:YOLOv5-3.1: Creating Directories...Done
15:34:23:YOLOv5-3.1: Installing module YOLOv5-3.1
15:34:23:YOLOv5-3.1: Installing python.= in C:\Program Files\CodeProject\AI\runtimes\bin\windows\python.=
15:34:23:YOLOv5-3.1: Checking for python.= download...Present
15:34:23:YOLOv5-3.1: '"C:\Program Files\CodeProject\AI\runtimes\bin\windows\python.=\python.exe"' is not recognized as an internal or external command,
15:34:23:YOLOv5-3.1: operable program or batch file.
15:34:24:YOLOv5-3.1: Creating Virtual Environment...Done
15:34:24:YOLOv5-3.1: The system cannot find the path specified.
15:34:24:YOLOv5-3.1: Enabling our Virtual Environment...Done
15:34:24:YOLOv5-3.1: Confirming we have Python ...
15:34:24:Module YOLOv5-3.1 installed successfully.
15:34:24:Module YOLOv5-3.1 not configured to AutoStart.
15:34:24:Installer exited with code 255
15:34:24:Unknown response from server
5:23:29:Error trying to start Object Detection (YOLOv5 .NET) (ObjectDetectionNet.exe)
15:23:29:An error occurred trying to start process 'C:\Program Files\CodeProject\AI\modules\ObjectDetectionNet\ObjectDetectionNet.exe' with working directory 'C:\Program Files\CodeProject\AI\modules\ObjectDetectionNet'. The system cannot find the file specified.
15:23:29: at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
at CodeProject.AI.API.Server.Frontend.ModuleProcessServices.StartProcess(ModuleConfig module)
15:23:29:Please check the CodeProject.AI installation completed successfully
There was some server issues where the file get downloaded from, it should be fixed nowUnfortunately no amount of waiting works for me. Uninstalling, reinstalled and starting any of the modules result in these errors.
Code:15:33:18:Server: This is the latest version 15:34:23:Preparing to install module 'YOLOv5-3.1' 15:34:23:Downloading module 'YOLOv5-3.1' 15:34:23:Installing module 'YOLOv5-3.1' 15:34:23:YOLOv5-3.1: Installing CodeProject.AI Analysis Module 15:34:23:YOLOv5-3.1: ======================================================================== 15:34:23:YOLOv5-3.1: CodeProject.AI Installer 15:34:23:YOLOv5-3.1: ======================================================================== 15:34:23:YOLOv5-3.1: Checking GPU support 15:34:23:YOLOv5-3.1: CUDA Present...False 15:34:23:YOLOv5-3.1: Allowing GPU Support: Yes 15:34:23:YOLOv5-3.1: Allowing CUDA Support: No 15:34:23:YOLOv5-3.1: General CodeProject.AI setup 15:34:23:YOLOv5-3.1: Creating Directories...Done 15:34:23:YOLOv5-3.1: Installing module YOLOv5-3.1 15:34:23:YOLOv5-3.1: Installing python.= in C:\Program Files\CodeProject\AI\runtimes\bin\windows\python.= 15:34:23:YOLOv5-3.1: Checking for python.= download...Present 15:34:23:YOLOv5-3.1: '"C:\Program Files\CodeProject\AI\runtimes\bin\windows\python.=\python.exe"' is not recognized as an internal or external command, 15:34:23:YOLOv5-3.1: operable program or batch file. 15:34:24:YOLOv5-3.1: Creating Virtual Environment...Done 15:34:24:YOLOv5-3.1: The system cannot find the path specified. 15:34:24:YOLOv5-3.1: Enabling our Virtual Environment...Done 15:34:24:YOLOv5-3.1: The system cannot find the path specified. 15:34:24:YOLOv5-3.1: Confirming we have Python ... 15:34:24:Module YOLOv5-3.1 installed successfully. 15:34:24:Module YOLOv5-3.1 not configured to AutoStart. 15:34:24:Installer exited with code 255 15:34:24:Unknown response from server
Code:5:23:29:Error trying to start Object Detection (YOLOv5 .NET) (ObjectDetectionNet.exe) 15:23:29:An error occurred trying to start process 'C:\Program Files\CodeProject\AI\modules\ObjectDetectionNet\ObjectDetectionNet.exe' with working directory 'C:\Program Files\CodeProject\AI\modules\ObjectDetectionNet'. The system cannot find the file specified. 15:23:29: at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo) at CodeProject.AI.API.Server.Frontend.ModuleProcessServices.StartProcess(ModuleConfig module) 15:23:29:Please check the CodeProject.AI installation completed successfully
