Wonder if there is a UPS that could keep my BI machine running for over a hour? It's about 100 watt machine.
gonna be cheaper to build a new BI machine that runs off 30-50W
Did you end up using one? Installed mine last week, hp box with BI, 2 zyxel 8port poe+ switches with 6 cams, Asus router,cable modem, and hdmi extender, gives me an estimated time of 19 minutes in the daytime, haven't checked the difference with IR turned on.Well that didn't give me any warm and fuzzies.
take your extender off the battery side..no need to have that running during an outage.Did you end up using one? Installed mine last week, hp box with BI, 2 zyxel 8port poe+ switches with 6 cams, Asus router and hdmi extender, gives me an estimated time of 19 minutes in the daytime, haven't checked the difference with IR turned on.
Agreed, I have to address the cooling issue in the server case first before I try cramming the UPS in there... sitting at 102 degrees inside... good catch though, I didn't even think about it to be honest.take your extender off the battery side..no need to have that running during an outage.
Curious are you happy with the UPS?Yes I did. It's been running a week and no problems. Based on that review, I get a chance, I may tear it apart and check the soldering job.
