First of all, sorry for my english, not my first language. But im pretty sure you guys can understand pretty well.
I have a Hikvision Camera for ANPR (Hikvision DeepinView Series/IP Camera/ iDS-2CD7A26G0/P-IZHS).
I made a post some weeks ago, asking for help with my camera positioning as i would like to use it in a straight corridor. The positioning then was very bad and most messages i received were from people asking me to change the camera location (too high
/the wall was in front of it). And so i did (was about to do it anyways).
My camera is in a pretty good spot right now (at least i thought so) , as it is almost aligned with the license plate from the cars and in a good distance. But the problem is that the performance is horrible now. In the position the camera were before, even tho it had some problems,i could get like 85% of license plates. Now, i can barely get like 50%.
The camera is missing some pretty "obvious" plates, as you will see in the pictue i will post. Most of the time, the cars go by the blue line (which was supposed to take a snap, and it did before) and the camera does nothing. It is indeed capable of taking license plates pretty far away, but it's missing a lot and i have no idea why.
Im not very experienced with ANPR cameras,and i would like any suggestion you guys have. I just don't know if there is any config that could make it better, or if i should phisically reduce the camera angle so it gets better precision.
Thanks in advance.
Thanks in advance.
