bad morning
bababouy
1,048
1,630
almost to the bottom
Both of these incidents happened at the same property, on the same morning. The gate operator was changed out the night before and the timer was set to zero, which means it opened then closed with no delay. The loop detector on the inside of the gate, in the ground, was also turned off. Everyone involved is ok, including the gate.
The guy on the bike picked a really good time to get off. As for the gate, I'm guessing you're definition of "ok" and mine are not quite the same...
Reactions: nayr
Gate should be a pretty cheap repair if it didn't damage the opener. That's probably why it's "OK".
Gee, Wonder why that first SUV had no front bumper :idk:
The first SUV got a bent hood out of the deal too!
