I had my clips written as .BVR directly to a USB 3 external drive on my network. The drive is hooked up to my router , both safely in the attic away from thieves. The logic being, that if my computer downstairs, which is running Blue Iris , was stolen I would still have the footage in the attic. All was going fine then the footage became very choppy and playback was useless. The only change I can see was from BI updates. So anyhow I changed the clip storage path to the local hard drive which is running BI and now the clips are playing back the way they should.
My question is how can I write these clips to the USB drive also. And not by a scheduled backup but immediately after the writing begins on my local drive.
I see that in Camera Properties/record tab/ there is a tickable box " Queue new clips for backup" - What does that mean? I can't find anything in Help. Also if there is a way to do it, converting to MP4 for the copies would be good.
Top of the season All.
