It seems to do what it wantsanyone else B-I up/down/rows not evenly spaced
my bottom row of cameras is larger then the rest of rows
its been like this for me for many versions now
ver 4.5.0.0
post an imageanyone else B-I up/down/rows not evenly spaced
ver 4.5.0.0
post an image
are you running cameras at different resolutions from each other?
That is normal and expected..the cameras are different aspect rations, the only way to make them even is to artificially stretch the image which would make things look weird...yeah i still have a few old school 640480's in use
the first 3 rows look even
the last row isnt
i had a feeling that was the caseThat is normal and expected..the cameras are different aspect rations, the only way to make them even is to artificially stretch the image which would make things look weird...
You can use blue iris's anamorphic setting in the camera video tab to manipulate the aspect ration but it will record the image that way as well (if you really want this you can clone the cams and record the proper aspect ration and live display the others)
There really small ones look like 1080p cameras in corridor mode.That is odd, I have four rows of cams with a mixture of 640x480 & 1920 x 1080 but only 4 cams per row. What are those real small cam windows you have in row 3 ? You could try to disable certain cams and the hide them too see if a particular cam is causing issue. I even tried adding a couple of new dummy cams so I would get 5 cams in a row, but all of my rows remain same size top to bottom.
the small ones are hik 1080p cameras in corridor mode
if i disabled one of the 640 cams it looks normal which ends up at 20 cams
