Hi,
For the Axis m5014, the default settings in Blue Iris don't provide a way to add a Sub stream. I choose
Make: Axis
Model: *M/P/Q series H.264
The Main stream profile is : /axis-media/media.amp?videocodec=h264&size=1&camera={CAMNO}
This translate to 0.9MP, 6.49/0.20 fps, 700 kB/s (I don't know why, but I can't get it to go up to the 30 fps it's supposed to be able to provide.... but that's for another thread)
I wanted to setup a substream to be easier on resources so I did this:
Make: Generic/ONVIF
Model: *RTSP H.264/H.265/MJPG/MPEG4
Main: /axis-media/media.amp?videocodec=h264&resolution=1280x720&compression=20&fps=6&videokeyframeinterval=6&videobitrate=0
Sub: /axis-media/media.amp?videocodec=h264&resolution=1280x720&compression=50&fps=6&videokeyframeinterval=6&videobitrate=424&videobitratepriority=framerate
This translate to :
Main: 0.9MP, 6.03/1.00 fps, 845 kB/s
Sub: 0.9MP, 3.08/1.04 fps, 56 kB/s
Should I bother and create a sub has above? Or should I just use the default method without the sub? Is it worth it to use a sub in this case?
See the status below. Cash is the one with the sum. Cash2 is the one with the original method without the sub:
Make: Axis
Make: Generic/ONVIF
This translate to :
