Hi,
here are two 5 minute sample clips of the Axis M1135 Camera at daytime, one is with lens setting 3 mm, the other with 10,5 mm.
Firmware Version 10.0.2
Streamsettings:
Resolution 1920x1080
Frame rate 25 fps
Compression 0
Zipstream off
P-Frames 50
Compression Profile high
Bit rate 8.192 kbit / s
Image settings:
WDR on
Saturation 66
Contrast 60
Brightness 45
Sharpness 70
Streamsettings:
Frame rate 25 fps
Compression 0
Zipstream off
P-Frames 50
Image settings:
WDR on
Saturation 66
Contrast 60
Brightness 45
Sharpness 70
