- Nov 6, 2015
- 8
- 0
Selling 3 like new Axis Communications P1427-LE outdoor bullet style security cameras. All three cameras are in like new physical and operating condition. 2 come in original boxes. I purchased these at B&H for $677.22 each, selling all 3 for $1500.
Axis Communications P1427-LE Overview
The P1427-LE 5MP Outdoor Bullet Camera from AXIS Communications uses a 1/3.2" progressive-scan CMOS sensor for 2592 x 1944 resolution at 12 fps, and it features a 2.8-9.8mm varifocal lens for a 27° to 92° horizontal field of view. Built-in IR LEDs provide up to 50' of night vision, and a removable IR cut filter automatically switches between color and B&W for clear details in low lighting. Wide dynamic range offers high-quality images in ambient lighting, and brightness, sharpness, white balance, and backlight compensation features allow you to configure your camera based on different environments. The camera also comes with built-in analytics, such as motion detection, autotracking, and line crossing. When any of these events occur, the camera will send you an email notification or store video recordings of the event to your edge storage.
The camera compresses footage using H.264 and MJPEG formatting, maximizing your bandwidth and storage. Additionally, video can be streamed in multiple individual streams, and frame rates and bandwidth are controllable for further customizing your network. A microSD slot supports on-site recording, however, the camera can also record remotely to a dedicated NAS. The network is secured with a number of safety features, including password protection, IP address filtering, and HTTPs encryption. ONVIF-compliance provides compatibility with a wide range of surveillance devices for connecting your camera to an NVR or NAS. PoE technology allows you to transfer both data and power over the same Ethernet cable, minimizing the amount of cables needed during installation, and the camera is IP66- and NEMA 4X-rated weatherproof for use outdoors.
PRODUCT HIGHLIGHTS
2592 x 1944 resolution at 12 fps (or 1080p up to 30 fps) for high quality video in real time
2.8-9.8mm fixed lens, with an f/1.6 aperture, for a 27° to 92° horizontal FOV
IR LEDs with adjustable intensity and angle of illumination provide night vision at a distance of up to 50'
Automatically removable infrared-cut filter for true day/night functionality
Multiple, individually configurable streams in H.264 and MJPEG formatting
Controllable frame rate and bandwidth (VBR/MBR H.264)
Multiple image settings such as WDR, manual shutter, exposure control, and text and image overlay
Image enhancements include color, brightness, sharpness, white balance, and backlight compensation
Motion detection, line crossing, and autotracking analytics
Day/Night mode, storage disruption, and live stream accessed tampering will trigger an event alarm
When an alarm is triggered the camera will send you an email notification or save a video recording to edge storage
Network security features such as password protection, IP address filtering, and HTTPs encryption
PoE technology allows you to use one wire for both data and power
microSD slot supports microSD cards for edge storage
IP66- and NEMA 4X-rated weatherproof casing for use outdoors
PRODUCT HIGHLIGHTS
