I have two 2387's and i was wondering if anyone has figured out a way to automatically make the SCENE's change based on sunrise/sunset, or even by using a light meter of some sort. Similar to the Dahua Sunrise/Sunset program that's out there.
Firmwares actually contain getLux function (saw using RCE and shell access to G2) but i havent seen anywhere on ISAPI or SDK documentation that we can use it as integrators. I believe its purely internal command for IR trigger.
Yes I've got the scene switching back and forth using postman and now have to figure out how to implement that in node-red.Well use postman, any settings you can do on website you can clone the request from inspect element looking at network tab
node-red i googled a bit and it sounds mind blowing when it comes to simple tasks
