Attention Adding Failed...LTS NVR
Feb 16, 2019
1
Phoenix, AZ
So I'm trying to connect 4 LTS IP Cameras to my LTS NVR, these 4 are on a remote building connected via a Ubiquiti link (this is the second building I am connecting this way, building 1 is working beautifully).
I see my 4 cameras pop up in the camera list and when I go to add them I get the little hour glass then "Attention Adding Failed" no explanation nothing.. Internet in the building is working great off the switch and the airMax signal and quality are great, so I know it's not an issue with the antenna setup.
The first time I did it the security field changed to a green check mark and the word active appeared, but it still has the default IP 192.0.0.64 in the next column.
Scratching my head only because I've run out of hair to pull out, TIA
