You're welcome. Can you share your server.conf and client.ovpn files here? Do remove any 210.x address from it, leave private 192.168/10.8 addresses. Then we know which routes/DNS the server is trying to push towards the client.
Thanks & goodnight!
CC
I am unsure where I could export a server.conf file but the following is my settings on the router:
WAN IP with 210.x.x.x
LAN IP = 192.168.1.1
LAN Devices IP in the 192.168.1.xxx range
VPN Server Settings as follows:
Interface Type: TUN
Protocol: UDP
Server Port: 443
Respond to DNS: Yes
Advertise DNS to Clients: Yes
Encryption Cipher: AES-256-CBC
HMAC Authentication: SHA 1
Compression: Disabled
Authorization Mode: TLS
Username / Password Auth. Only: No
RSA Encryption: 1024 bit
Extra HMAC Authorization: Disable
VPN Subnet/Netmask: 10.8.0.0 / 255.255.255.0
Push LAN to Clients: Yes
Direct Clients to Redirect Internet Traffic: Yes
TLS Renegotiation Time: -1
Manage Client-Specific Options: No
Also unable to upload the client.ovpn files but below is the log from the client when connected to the server:
Open VPN Start
OpenVPN core 3.2 ios arm64 64-bit PT_PROXY
Frame = 512/2048/512 mssfix-ctrl=1250
UNUSED OPTIONS
2 [nobind]
5 [sndbuf] [0]
6 [rcvbuf] [0]
EVENT : RESOLVE
Contacting [210.x.x.x]:443/UDP via UDP
EVENT : WAIT
Connecting to [vpn.asuscomm.com]:443 (210.x.x.x) via UDPv4
EVENT: CONNECTING
Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,protoUDPv4,comp-lz0,cipher AES-256-CBC,authSHA1,keysize 256,key-method 2,tls-client
Creds: Username/Password
Peer Info: IV_GUI_VER=net.openvpn.connect.ios 3.0.1-770
IV_VER=3.2
IV_PLAT=ios
IV_NVP=2
IV_TCPNL=1
IV_PRONTO=2
VERIFY OK: depth=0
Cert.version: 3
Serial number: 01
Issuer name: C=TW, ST=TW, L= Taipei,O=ASUS,CN=RT-AC68U
[email protected]
subject name: C=TW,ST=TW,L=Taipei,O=ASUS,CN=RT-AC68U,
[email protected]
issued on: 2018-09-15
expires on: 2028-09-12
signed using: RSA with SHA1
RSA kev size: 1024 bits
Basic constraints: CA=false
Cert.type: SSL Server
Key usage: Digital Signature, Key Encipherment
Ext key usage: TLS Web Server Authentication
SSL Handshake: TLSv1.0/TLS-DHE-RSA-WITH-3DES-EDE-CBC-SHA
Session is ACTIVE
EVENT: GET_CONFIG
Sending PUSH_REQUEST to server…..
OPTIONS:
0 [route] [192.168.1.0] [255.255.255.0][vpn_gateway][500]
1[redirect-gateway][def1]
2[dhcp-option][DNS][192.168.1.1]
3[route][10.8.0.1]
4[topology][net30]
5[ping][15]
6[ping-restart][60]
7[ifconfig][10.8.0.6][10.8.0.5]
PROTOCOL OPTIONS:
Cipher: AES-256-CBC
Digest: SHA1
Compress: LZO
Peer ID: -1
EVENT: ASSIGN_IP
NIP: preparing TUN network settings
NIP: init TUN network settings with endpoint: 210.x.x.x
NIP: adding IPv4 address to network settings 10.8.0.6/255.255.255.252
NIP: adding(included)IPv4 route 10.8.0.4/30
NIP: adding(included) IPv4 route 192.168.1.0/24
NIP: adding(included) IPv4 route 10.8.0.1/32
NIP: redirecting all IPv4 traffic to TUN interface
NIP: adding DNS 192.168.1.1
Connected via NetworkExtentionTUN
EVENT:CONNECTED [email protected]:443 (210.x.x.x) via /UDPv4 on NetworkExtensionTUN/10.8.0.6/ gw=[/]
