- Mar 9, 2014
- 36,891
- 21,417
Came across this asus unit that is affordable and easy to setup with vlan support. This is one feature that is lacking in almost all easy to use home routers. It is only 150 bux. In the past I have recommended the synology rt6600 or wrx560 which are priced at 300 and 220 respectively. I just ordered one of these to play and likely install for a relative.
Yes I am aware that you can roll your own but this makes it easy for anyone running a camera system or iot devices to easily segment them.
EDIT: Unfortunately this is going back. See below.
Try this instead Ubiquiti Networks Cloud Gateway Ultra
