Hi all,
Seeking advise on cameras to use with Blue Iris
Currently using BI with 5 X 2mp outdoor Bullet cameras, looking at the 8mp on AliExpress and alike (2-4 pending price and benefit etc)
I am still getting my head around parameters of the hardware and what it means! So if I type something that does make sense it probably from a lack of understanding.
The 8mp with 4m or 6mm lens gives a very wide angle and not great quality from distance (looking at calculator.ipvm.com)
When I find a camera with a vari-lens, I see 10mm or 12mm giving a similar angle as my current 2mp and good quality at distance… can also adjust to suit
Bunch of questions:
What/where should I be looking at for best price/quality? – can you get fixed 10/12mm lens? – can you buy the lens to swap out fi you need more/less angle? – is this easy to do?
Looking at H.265 capable also (Will BI do this regardless??)
I understand that the night vision might not be as good (well I read that but don’t understand if I am being completely honest!) – I can install some security lights if that will assist?
Can anyone point me towards some good cameras, prefer POE but if not that’s OK to
Looking at the below as examples – I am also in Australia
https://www.aliexpress.com/item/Long-IR-Distance-H-265-ONVIF-8MP-4K-POE-Network-IP-CCTV-Outdoor-Bullet-Waterproof-Security/33013164623.html
http://s.click.aliexpress.com/e/bxRYvhqY
Appreciate any advice!
Tro
Bunch of questions:
Tro
