Are Reolink Duo POE 3 cameras hopeless?
dooraccess
Sep 18, 2023
7
Canada
Hi everyone, I have 6 Reolink Duo POE dome cameras with following issues. I am using Frigate, and I want to rule out Frigate or the PC resources issue. I have run the cameras at 4096*1152 and Frigate has no complains. But when I change to 7680*2160 I get complains like below in Frigate logs. Also, two of the cameras all a sudden shrunk in Live view and Frigate people say it is a camera issue and not Frigate. How to know this for sure. And is there a firmware that Reolink support can send me to fix these issues? I don't see a Stretch Mode in Reolink UI. My wires are Fluke tested to 10/100/1000 Mbps and network is simple and fine.
And finally, is there a proven camera that has the following that folks here recommend:
  • 8MP
  • Hybrid night light for color with ability to stay ON on demand
  • Alarm / Speaker
  • Microphone
  • No reflection on dome screen
  • POE
Thanks
Frigate logs:
2025-11-14 12:26:22.862912 2025-11-14 10:14:11.224817198
2025-11-14 12:26:22.862918 2025-11-14 10:14:11.224818602
2025-11-14 10:14:11.236434061 [2025-11-14 10:14:11] frigate.record.maintainer WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2025-11-14 10:14:11.236711033 [2025-11-14 10:14:11] frigate.record.maintainer WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2025-11-14 10:14:20.553429850 [2025-11-14 10:14:20] watchdog.Side_Right_Back ERROR : No new recording segments were created for Side_Right_Back in the last 120s. restarting the ffmpeg record process...
2025-11-14 10:14:20.553997757 [2025-11-14 10:14:20] watchdog.Side_Right_Back INFO : Terminating the existing ffmpeg process...
2025-11-14 10:14:20.556505385 [2025-11-14 10:14:20] watchdog.Side_Right_Back INFO : Waiting for ffmpeg to exit gracefully...
2025-11-14 10:14:26.230880119 [ WARN:[email protected]] global cap.cpp:175 open VIDEOIO(CV_IMAGES): raised OpenCV exception:
2025-11-14 12:26:22.862934 2025-11-14 10:14:26.230888034
2025-11-14 10:14:26.230895928 OpenCV(4.11.0) /io/opencv/modules/videoio/src/cap_images.cpp:267: error: (-215:Assertion failed) number < max_number in function 'icvExtractPattern'
2025-11-14 12:26:22.862942 2025-11-14 10:14:26.230899033
2025-11-14 12:26:22.862948 2025-11-14 10:14:26.230901653
2025-11-14 10:14:26.256315797 [2025-11-14 10:14:26] frigate.record.maintainer WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2025-11-14 10:14:26.256863519 [2025-11-14 10:14:26] frigate.record.maintainer WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2025-11-14 10:14:32.580197801 [2025-11-14 10:14:32] watchdog.Side_Right_Back ERROR : No new recording segments were created for Side_Right_Back in the last 120s. restarting the ffmpeg record process...
2025-11-14 10:14:32.581588990 [2025-11-14 10:14:32] watchdog.Side_Right_Back INFO : Terminating the existing ffmpeg process...
2025-11-14 10:14:32.582436075 [2025-11-14 10:14:32] watchdog.Side_Right_Back INFO : Waiting for ffmpeg to exit gracefully...
2025-11-14 10:14:36.219362706 [ WARN:[email protected]] global cap.cpp:175 open VIDEOIO(CV_IMAGES): raised OpenCV exception:
2025-11-14 12:26:22.862964 2025-11-14 10:14:36.219367885
2025-11-14 10:14:36.219372095 OpenCV(4.11.0) /io/opencv/modules/videoio/src/cap_images.cpp:267: error: (-215:Assertion failed) number < max_number in function 'icvExtractPattern'
2025-11-14 12:26:22.862972 2025-11-14 10:14:36.219373884
2025-11-14 12:26:22.862978 2025-11-14 10:14:36.219375555
2025-11-14 10:14:36.257926180 [2025-11-14 10:14:36] frigate.record.maintainer WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2025-11-14 10:14:36.258485310 [2025-11-14 10:14:36] frigate.record.maintainer WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2025-11-14 12:03:05.197679619 [2025-11-14 12:03:05] watchdog.Side_Right_Back ERROR : No new recording segments were created for Side_Right_Back in the last 120s. restarting the ffmpeg record process...
2025-11-14 12:03:05.198551542 [2025-11-14 12:03:05] watchdog.Side_Right_Back INFO : Terminating the existing ffmpeg process...
2025-11-14 12:03:05.199061861 [2025-11-14 12:03:05] watchdog.Side_Right_Back INFO : Waiting for ffmpeg to exit gracefully...
2025-11-14 12:03:15.374576774 [2025-11-14 12:03:15] watchdog.Side_Right_Back ERROR : No new recording segments were created for Side_Right_Back in the last 120s. restarting the ffmpeg record process...
2025-11-14 12:03:15.375731301 [2025-11-14 12:03:15] watchdog.Side_Right_Back INFO : Terminating the existing ffmpeg process...
2025-11-14 12:03:15.375741879 [2025-11-14 12:03:15] watchdog.Side_Right_Back INFO : Waiting for ffmpeg to exit gracefully...
2025-11-14 12:03:21.473671537 [ WARN:[email protected]] global cap.cpp:175 open VIDEOIO(CV_IMAGES): raised OpenCV exception:
2025-11-14 12:26:22.862999 2025-11-14 12:03:21.473677559
2025-11-14 12:03:21.473681766 OpenCV(4.11.0) /io/opencv/modules/videoio/src/cap_images.cpp:267: error: (-215:Assertion failed) number < max_number in function 'icvExtractPattern'
2025-11-14 12:26:22.863007 2025-11-14 12:03:21.473683544
2025-11-14 12:26:22.863013 2025-11-14 12:03:21.473685217
2025-11-14 12:03:21.486185379 [2025-11-14 12:03:21] frigate.record.maintainer WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2025-11-14 12:03:21.486439242 [2025-11-14 12:03:21] frigate.record.maintainer WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2025-11-14 12:03:27.499210900 [2025-11-14 12:03:27] watchdog.Side_Right_Back ERROR : No new recording segments were created for Side_Right_Back in the last 120s. restarting the ffmpeg record process...
2025-11-14 12:03:27.502312356 [2025-11-14 12:03:27] watchdog.Side_Right_Back INFO : Terminating the existing ffmpeg process...
2025-11-14 12:03:27.503238750 [2025-11-14 12:03:27] watchdog.Side_Right_Back INFO : Waiting for ffmpeg to exit gracefully...
2025-11-14 12:03:31.478814135 [ WARN:[email protected]] global cap.cpp:175 open VIDEOIO(CV_IMAGES): raised OpenCV exception:
2025-11-14 12:26:22.863029 2025-11-14 12:03:31.478821034
2025-11-14 12:03:31.478827060 OpenCV(4.11.0) /io/opencv/modules/videoio/src/cap_images.cpp:267: error: (-215:Assertion failed) number < max_number in function 'icvExtractPattern'
2025-11-14 12:26:22.863037 2025-11-14 12:03:31.478829325
2025-11-14 12:26:22.863043 2025-11-14 12:03:31.478831465
2025-11-14 12:03:31.489781015 [2025-11-14 12:03:31] frigate.record.maintainer WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2025-11-14 12:03:31.490078854 [2025-11-14 12:03:31] frigate.record.maintainer WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2025-11-14 12:12:59.566073500 [2025-11-14 12:12:59] watchdog.Side_Right_Back ERROR : No new recording segments were created for Side_Right_Back in the last 120s. restarting the ffmpeg record process...
2025-11-14 12:12:59.566981827 [2025-11-14 12:12:59] watchdog.Side_Right_Back INFO : Terminating the existing ffmpeg process...
2025-11-14 12:12:59.567504583 [2025-11-14 12:12:59] watchdog.Side_Right_Back INFO : Waiting for ffmpeg to exit gracefully...
2025-11-14 12:13:10.035597064 [2025-11-14 12:13:10] watchdog.Side_Right_Back ERROR : No new recording segments were created for Side_Right_Back in the last 120s. restarting the ffmpeg record process...
2025-11-14 12:13:10.036449837 [2025-11-14 12:13:10] watchdog.Side_Right_Back INFO : Terminating the existing ffmpeg process...
2025-11-14 12:13:10.037097684 [2025-11-14 12:13:10] watchdog.Side_Right_Back INFO : Waiting for ffmpeg to exit gracefully...
2025-11-14 12:13:16.497913587 [ WARN:[email protected]] global cap.cpp:175 open VIDEOIO(CV_IMAGES): raised OpenCV exception:
2025-11-14 12:26:22.863064 2025-11-14 12:13:16.497921082
2025-11-14 12:13:16.497928252 OpenCV(4.11.0) /io/opencv/modules/videoio/src/cap_images.cpp:267: error: (-215:Assertion failed) number < max_number in function 'icvExtractPattern'
2025-11-14 12:26:22.863072 2025-11-14 12:13:16.497931052
2025-11-14 12:26:22.863078 2025-11-14 12:13:16.497933395
2025-11-14 12:13:16.521872621 [2025-11-14 12:13:16] frigate.record.maintainer WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2025-11-14 12:13:16.524456907 [2025-11-14 12:13:16] frigate.record.maintainer WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2025-11-14 12:13:22.013126995 [2025-11-14 12:13:22] watchdog.Side_Right_Back ERROR : No new recording segments were created for Side_Right_Back in the last 120s. restarting the ffmpeg record process...
2025-11-14 12:13:22.014265001 [2025-11-14 12:13:22] watchdog.Side_Right_Back INFO : Terminating the existing ffmpeg process...
2025-11-14 12:13:22.014995675 [2025-11-14 12:13:22] watchdog.Side_Right_Back INFO : Waiting for ffmpeg to exit gracefully...
2025-11-14 12:13:26.501225729 [ WARN:[email protected]] global cap.cpp:175 open VIDEOIO(CV_IMAGES): raised OpenCV exception:
2025-11-14 12:26:22.863094 2025-11-14 12:13:26.501234740
2025-11-14 12:13:26.501243615 OpenCV(4.11.0) /io/opencv/modules/videoio/src/cap_images.cpp:267: error: (-215:Assertion failed) number < max_number in function 'icvExtractPattern'
2025-11-14 12:26:22.863102 2025-11-14 12:13:26.501247006
2025-11-14 12:26:22.863108 2025-11-14 12:13:26.501250030
2025-11-14 12:13:26.534932313 [2025-11-14 12:13:26] frigate.record.maintainer WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2025-11-14 12:13:26.534939782 [2025-11-14 12:13:26] frigate.record.maintainer WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2025-11-14 12:13:34.138056588 [2025-11-14 12:13:34] watchdog.Side_Right_Back ERROR : No new recording segments were created for Side_Right_Back in the last 120s. restarting the ffmpeg record process...
2025-11-14 12:13:34.139373543 [2025-11-14 12:13:34] watchdog.Side_Right_Back INFO : Terminating the existing ffmpeg process...
2025-11-14 12:13:34.142253479 [2025-11-14 12:13:34] watchdog.Side_Right_Back INFO : Waiting for ffmpeg to exit gracefully...
2025-11-14 12:13:36.508653440 [ WARN:[email protected]] global cap.cpp:175 open VIDEOIO(CV_IMAGES): raised OpenCV exception:
2025-11-14 12:26:22.863123 2025-11-14 12:13:36.508662378
2025-11-14 12:13:36.508669627 OpenCV(4.11.0) /io/opencv/modules/videoio/src/cap_images.cpp:267: error: (-215:Assertion failed) number < max_number in function 'icvExtractPattern'
2025-11-14 12:26:22.863132 2025-11-14 12:13:36.508672850
2025-11-14 12:26:22.863137 2025-11-14 12:13:36.508675943
2025-11-14 12:13:36.562334118 [2025-11-14 12:13:36] frigate.record.maintainer WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2025-11-14 12:13:36.562904815 [2025-11-14 12:13:36] frigate.record.maintainer WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2025-11-14 12:13:46.163935054 [2025-11-14 12:13:46] watchdog.Side_Right_Back ERROR : No new recording segments were created for Side_Right_Back in the last 120s. restarting the ffmpeg record process...
2025-11-14 12:13:46.164394995 [2025-11-14 12:13:46] watchdog.Side_Right_Back INFO : Terminating the existing ffmpeg process...
2025-11-14 12:13:46.164757927 [2025-11-14 12:13:46] watchdog.Side_Right_Back INFO : Waiting for ffmpeg to exit gracefully...
2025-11-14 12:13:51.497938681 [ WARN:[email protected]] global cap.cpp:175 open VIDEOIO(CV_IMAGES): raised OpenCV exception:
2025-11-14 12:26:22.863153 2025-11-14 12:13:51.497943806
2025-11-14 12:13:51.497948326 OpenCV(4.11.0) /io/opencv/modules/videoio/src/cap_images.cpp:267: error: (-215:Assertion failed) number < max_number in function 'icvExtractPattern'
2025-11-14 12:26:22.863161 2025-11-14 12:13:51.497949841
2025-11-14 12:26:22.863167 2025-11-14 12:13:51.497951262
2025-11-14 12:13:51.515462305 [2025-11-14 12:13:51] frigate.record.maintainer WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2025-11-14 12:13:51.515756936 [2025-11-14 12:13:51] frigate.record.maintainer WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2025-11-14 12:13:58.135504620 [2025-11-14 12:13:58] watchdog.Side_Right_Back ERROR : No new recording segments were created for Side_Right_Back in the last 120s. restarting the ffmpeg record process...
2025-11-14 12:13:58.135881945 [2025-11-14 12:13:58] watchdog.Side_Right_Back INFO : Terminating the existing ffmpeg process...
2025-11-14 12:13:58.136223244 [2025-11-14 12:13:58] watchdog.Side_Right_Back INFO : Waiting for ffmpeg to exit gracefully...
2025-11-14 12:14:01.494403992 [ WARN:[email protected]] global cap.cpp:175 open VIDEOIO(CV_IMAGES): raised OpenCV exception:
2025-11-14 12:26:22.863183 2025-11-14 12:14:01.494409717
2025-11-14 12:14:01.494413541 OpenCV(4.11.0) /io/opencv/modules/videoio/src/cap_images.cpp:267: error: (-215:Assertion failed) number < max_number in function 'icvExtractPattern'
2025-11-14 12:26:22.863190 2025-11-14 12:14:01.494415146
2025-11-14 12:26:22.863196 2025-11-14 12:14:01.494416681
2025-11-14 12:14:01.506164895 [2025-11-14 12:14:01] frigate.record.maintainer WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2025-11-14 12:14:01.506434900 [2025-11-14 12:14:01] frigate.record.maintainer WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
