Been struggling for some days now.
Using BI built in Plate Recogniser (APLR) as looked easy & straight forward & detects LP's really well.
Testing using the alert button from the main page with all the cameras,
APLR Dashboard shows is has been detected correctly.
BI alerts on left now shows the correct LP at the bottom of that alert.
but does not run the BAT files.
If I have NO LP in the required AI Objects box, i.e. blank, it all works & runs the BAT.
If I put X50JOG in the required AI, and the detected alert is exactly the same, X50JPG but it does not run the BAT.
I have tried spaces not spaces, quotes, 2 or more LP with delimited with , (again no spaces)
If I click the run icon, test, in the alerts box, it works but only if I put X50JPG, so it is is reading & wants a listed LP.
As I say it is not a case of running as a service or anything like that as runs without AI & on just movement, I think it is the return of the LP but makes no sense now.
I do now have deepstack installed but a learning curve and no built in LPR, I would prefer but if APLR had worked/run as expected it would all been done in 10 minutes.
Any ideas
Thanks I/A
Any ideas
Thanks I/A
